[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Noli Sicad nsicad at gmail.com
Mon Aug 27 18:34:24 PDT 2012
Hi Julien,
Thanks for this instruction how to build / compile and install OTB for
Mac OS X and make QGIS Sextante OTB python plugin working in OS X.
I am using William's frameworks, "standard configure, make and make
install", and supplement things using Homebrew if I can't make things
working with the "standard configure...".
> With MacPort, install the following : expat, curl, tiff, geotiff, jpeg,
> gdal, mercurial, cmake, etc (I may have missed a few)
I think I can easily achieve those dependencies you mentioned.
> Grab this ctest script :
> http://hg.orfeo-toolbox.org/OTB-DevUtils/file/21ee66ab6fd3/Config/leod/leod-OTB-Nightly-macport_light.cmake
Looking at this cmake script, it seems that ITK is not needed after all.
Yes, I will have a go on this script (i.e. edit it) and see if I can
make it working.
Thanks again for your help.
Regards,
Noli
On 8/27/12, Julien Malik wrote:
> Hi Noli,
> For MacOSX, the easier path I know of is to use MacPort to install all
> the needed dependencies.
> And customize it :
> - change CTEST_SITE and CTEST_BUILDNAME to whatever you like
> - change CTEST_SOURCE_DIRECTORY and point to where you extracted the OTB
> sources
> - change CTEST_BINARY_DIRECTORY and point it to where the build file
> will live
> - change CMAKE_INSTALL_PREFIX to the path where OTB will be installed
> after successfull build
> - in the CTEST_INITIAL_CACHE part, you might want to change to :
> BUILD_TESTING:BOOL=OFF
> BUILD_EXAMPLES:BOOL=OFF
> BUILD_APPLICATIONS:BOOL=ON
> OTB_WRAP_PYTHON:BOOL=OFF
> OTB_WRAP_QT:BOOL=OFF
> OTB_WRAP_JAVA:BOOL=OFF
> to reduce the build time.
> Then from a shell, start :
> ctest -S <path_to_the_script> -VV
> Go to your build dir and type "make install"
> Then look in CMAKE_INSTALL_PREFIX/bin and you should be able to launch
> an OTB application (otbcli_Something scripts)
> Then in Sextante configuration, you should set :
> -"OTB command line tools" option to CMAKE_INSTALL_PREFIX/bin
> -"OTB applications folder" option to CMAKE_INSTALL_PREFIX/lib/otb
> And you're good to go.
> Good luck,
> Julien
