[Qgis-developer] API cleanup
kimaidou kimaidou at gmail.com
Thu Dec 20 01:47:50 PST 2012
Hi list
Ok for removing the deprecated methods, but we really need to have a
documented wiki page with a list of deprecated methods and the appropriate
replacement.
Classic use case : you have developed a plugin. After the api break, you
have several warning and error about "this method does not exists" -> hop,
you go to the dedicated web page and you can see which new method to use
instead.
Michael
2012/12/19 Nathan Woodrow <madmanwoo at gmail.com>
> Hey Alex,
> I think we should be removing them as I think that is a overall goal for
> 2.0.  I think we can just remove them.  We should be able to diff the API
> docs once 2.0 is out to find out which methods have been added or removed.
> That is my thinking anyway.
> - Nathan
> On Wed, Dec 19, 2012 at 10:00 PM, Alexander Bruy <alexander.bruy at gmail.com
> > wrote:
>> Hi all,
>> anyone works on API (both C++ and Python) cleanup? As I can see there
>> are about 90 deprecated methods available (for example, look at
>> QgsRasterLayer class), maybe we have even more, because not all
>> methods may be marked as deprecated.
>> Should we remove them? If yes which procedure is correct?
>> Thanks
>> Alexander Bruy
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121220/e2e52f9f/attachment.html>
