[Qgis-developer] API cleanup
Salvatore Larosa lrssvtml at gmail.com
Thu Dec 20 02:02:06 PST 2012
2012/12/20 kimaidou <kimaidou at gmail.com>
> Hi list
> Ok for removing the deprecated methods, but we really need to have a
> documented wiki page with a list of deprecated methods and the appropriate
> replacement.
there is already a wiki page [1], thanks to Pirmin Kalberer !
Regards,
-SL
[1] - http://hub.qgis.org/wiki/quantum-gis/API_changes_for_version_20
> Classic use case : you have developed a plugin. After the api break, you
> have several warning and error about "this method does not exists" -> hop,
> you go to the dedicated web page and you can see which new method to use
> instead.
> Michael
> 2012/12/19 Nathan Woodrow <madmanwoo at gmail.com>
>> Hey Alex,
>> I think we should be removing them as I think that is a overall goal for
>> 2.0.  I think we can just remove them.  We should be able to diff the API
>> docs once 2.0 is out to find out which methods have been added or removed.
>> That is my thinking anyway.
>> - Nathan
>> On Wed, Dec 19, 2012 at 10:00 PM, Alexander Bruy <
>> alexander.bruy at gmail.com> wrote:
>>> Hi all,
>>> anyone works on API (both C++ and Python) cleanup? As I can see there
>>> are about 90 deprecated methods available (for example, look at
>>> QgsRasterLayer class), maybe we have even more, because not all
>>> methods may be marked as deprecated.
>>> Should we remove them? If yes which procedure is correct?
>>> Thanks
>>> Alexander Bruy
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121220/60f98bec/attachment-0001.html>
