[Qgis-developer] API cleanup
Giuseppe Sucameli
sucameli at faunalia.it
Thu Dec 20 02:11:42 PST 2012
On Thu, Dec 20, 2012 at 11:02 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> 2012/12/20 kimaidou <kimaidou at gmail.com>
>> Ok for removing the deprecated methods, but we really need to have a
>> documented wiki page with a list of deprecated methods and the appropriate
>> replacement.
> there is already a wiki page [1]
in this moment that page contains only methods no longer
available in current master.
We must to add deprecated methods and their replacement to it
before removing them at all.
Regards.
> Regards,
> -SL
> [1] - http://hub.qgis.org/wiki/quantum-gis/API_changes_for_version_20
>> Classic use case : you have developed a plugin. After the api break, you
>> have several warning and error about "this method does not exists" -> hop,
>> you go to the dedicated web page and you can see which new method to use
>> instead.
>> Michael
>> 2012/12/19 Nathan Woodrow <madmanwoo at gmail.com>
>>> Hey Alex,
>>> I think we should be removing them as I think that is a overall goal for
>>> 2.0. I think we can just remove them. We should be able to diff the API
>>> docs once 2.0 is out to find out which methods have been added or removed.
>>> That is my thinking anyway.
>>> - Nathan
>>> On Wed, Dec 19, 2012 at 10:00 PM, Alexander Bruy
>>> <alexander.bruy at gmail.com> wrote:
>>>> Hi all,
>>>> anyone works on API (both C++ and Python) cleanup? As I can see there
>>>> are about 90 deprecated methods available (for example, look at
>>>> QgsRasterLayer class), maybe we have even more, because not all
>>>> methods may be marked as deprecated.
>>>> Should we remove them? If yes which procedure is correct?
>>>> Thanks
>>>> Alexander Bruy
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
Giuseppe Sucameli - Faunalia
