[Qgis-developer] R sc ript failed to work in SEXTANTE plugin for QGIS
KAM Tin Seong
tskam at smu.edu.sg
Sun Dec 23 03:14:42 PST 2012
Hi Victor, many thanks for the prompt reply.
What do you mean by "I guess that path with blank spaces might be problematic."? Please kindly enlighten me.
tskam
________________________________________
Sent: Sunday, 23 December, 2012 4:38:02 PM
To: KAM Tin Seong
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] R sc ript failed to work in SEXTANTE plugin for QGIS
You have 2.15 installed, but the one that is called from SEXTANTE is
2.14. Strange. You might have it installed somewhere else, and somehow
SEXTANTE is calling it.
I guess that path with blank spaces might be problematic. Maybe try to
install in a path with no blank spaces, and configure SEXTANTE to take
R from there...
That might also be causing the problem with the packages. Probably
they are installed where they should not be installed, and then the
library() command doesn't work. Maybe someone with better knowledge of
R can confirm this...
Regards
Victor
2012/12/23 KAM Tin Seong <tskam at smu.edu.sg>:
> I have R installed in C:\Program Files\R\R-2.15.2\bin and created R_PATH in
> Window environment setting. I have tested the setting by calling R in DOS
> prompt and it work properly. It is the i386 version. I also changed the
> configuration of R folder in SEXTANTE to C:\Program
> Files\R\R-2.15.2\bin\i386. When I run the Raster Histogram module of R
> within SEXTANTE the output was blank. Below is the History and Info log of
> SEXTANTE:
> R execution console output
> R version 2.14.1 (2011-12-22)
> Copyright (C) 2011 The R Foundation for Statistical Computing
> ISBN 3-900051-07-0
> Platform: i386-pc-mingw32/i386 (32-bit)
> R is free software and comes with ABSOLUTELY NO WARRANTY.
> You are welcome to redistribute it under certain conditions.
> Type 'license()' or 'licence()' for distribution details.
> Natural language support but running in an English locale
> R is a collaborative project with many contributors.
> Type 'contributors()' for more information and
> 'citation()' on how to cite R or R packages in publications.
> Type 'demo()' for some demos, 'help()' for on-line help, or
> 'help.start()' for an HTML browser interface to help.
> Type 'q()' to quit R.
> options("repos"="http://cran.us.r-project.org")
> tryCatch(find.package("rgdal"), error=function(e) install.packages("rgdal",
> lib="C:/Users/tskam/.qgis//sextante/rlibs"))
> trying URL
> 'http://cran.us.r-project.org/bin/windows/contrib/2.14/rgdal_0.7-25.zip'
> Content type 'application/zip' length 11772617 bytes (11.2 Mb)
> opened URL
> downloaded 11.2 Mb
> package 'rgdal' successfully unpacked and MD5 sums checked
> The downloaded packages are in
> C:\Users\tskam\AppData\Local\Temp\Rtmpkzwp01\downloaded_packages
> library("rgdal")
> Error in library("rgdal") : there is no package called 'rgdal'
> Execution halted
> There are two things which seem not correct. First the R installs in my
> computer is version 2.15.2 and not version 2.14.1 and I have very sure I
> have rgdal install because I have tested the same script using R GUI
> directly.
> It would be very much appreciated if someone can advise me how to solve this
> problem.
> Thanks in advance.
> tskam
> Qgis-developer mailing list
