[Qgis-developer] qt problem with JPEG on Ubuntu 12.04
Andreas Neumann
a.neumann at carto.net
Tue Dec 25 03:54:07 PST 2012
I upgraded my server from Ubuntu 10.04 LTS to 12.04 LTS. I recompiled
QGIS server with the new qt and JPEG libraries and the compile and
install went fine. However, since the upgrade, QGIS server cannot read
and write JPEG files anymore. QGIS server crashes whenever the source
(WMS) or the output involves a JPEG read or write. This is regardless of
the input raster source (could be TIFF or WMS). PNG and PNG8bit output
seems to work fine.
I googled for qt and JPEG problems, but could not find much that
sounded similar to my problem.
Using ldd I saw that qgis_mapserv.fcgi is linked against libjpeg.so.8 -
is this a problem? Should it be linked against libjpeg.so.62?
Thank you if you have any idea about my problem.
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
