[Qgis-developer] qt problem with JPEG on Ubuntu 12.04
    Marco Hugentobler
    marco.hugentobler at sourcepole.ch
    Tue Dec 25 04:32:07 PST 2012
Hi Andreas
I'm using 12.04 as well and it works for me with qgis_mapserv.fcgi
linked against libjpeg.so.8
Could you check, if you have Qt's jpeg plugin installed
(/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so) ? It is
contained in the package libqtgui4 and linked against libjpeg.so.8 too.
Regards,
Marco
On 25.12.2012 12:54, Andreas Neumann wrote:
> Hi,
> I upgraded my server from Ubuntu 10.04 LTS to 12.04 LTS. I recompiled
> QGIS server with the new qt and JPEG libraries and the compile and
> install went fine. However, since the upgrade, QGIS server cannot read
> and write JPEG files anymore. QGIS server crashes whenever the source
> (WMS) or the output involves a JPEG read or write. This is regardless
> of the input raster source (could be TIFF or WMS). PNG and PNG8bit
> output seems to work fine.
> I googled for qt and JPEG problems, but could not find much that
> sounded similar to my problem.
> Using ldd I saw that qgis_mapserv.fcgi is linked against libjpeg.so.8
> - is this a problem? Should it be linked against libjpeg.so.62?
> Thank you if you have any idea about my problem.
> Andreas
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
