[Qgis-developer] popups informing that transformation failed
should happen once, not for each point
Jürgen E. Fischer
jef at norbit.de
Fri Feb 10 09:43:17 EST 2012
Hi Etienne,
On Fri, 10. Feb 2012 at 11:32:16 -0200, Etienne Tourigny wrote:
> sometimes with on-the fly reprojection enabled, I get a very large
> number of popups with the message "forward transformation of ...
> failed with error : latitude or longitude exceeded limits".
Known problem (you are probably using valuetool), see
http://hub.qgis.org/issues/4905
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
