[Qgis-developer] popups informing that transformation failed should happen once, not for each point
Marco Bernasocchi marco at bernawebdesign.ch
Fri Feb 10 10:01:05 EST 2012
On 02/10/2012 03:43 PM, Jürgen E. Fischer wrote:
> Hi Etienne,
> On Fri, 10. Feb 2012 at 11:32:16 -0200, Etienne Tourigny wrote:
>> sometimes with on-the fly reprojection enabled, I get a very large
>> number of popups with the message "forward transformation of ...
>> failed with error : latitude or longitude exceeded limits".
> Known problem (you are probably using valuetool), see
> http://hub.qgis.org/issues/4905
> Jürgen
Hi Jürgen, I get the same error with gps tracking on. Don't know if it
is only on android or with all connections type (ive only android gps here).
ciao
Marco Bernasocchi
www.opengis.ch
