[Qgis-developer] popups informing that transformation failed
should happen once, not for each point
Jürgen E. Fischer
jef at norbit.de
Fri Feb 10 11:20:15 EST 2012
Hi Marco,
On Fri, 10. Feb 2012 at 16:01:05 +0100, Marco Bernasocchi wrote:
> Hi Jürgen, I get the same error with gps tracking on. Don't know if it
> is only on android or with all connections type (ive only android gps
> here).
Another known problem - from IRC ;)
You're probably also trying to transform invalid coordinates without catching
the associated exception.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
