[Qgis-developer] popups informing that transformation failed
should happen once, not for each point
Etienne Tourigny
etourigny.dev at gmail.com
Fri Feb 10 11:36:44 EST 2012
Sorry - I should have checked.
A more general question : what is the status of Master WRT plugin
support? I have been holding off updating my QGis installation from
master because but I don't want things to break, especially plugins
because of API changes.
regards,
Etienne
On Fri, Feb 10, 2012 at 12:43 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Etienne,
> On Fri, 10. Feb 2012 at 11:32:16 -0200, Etienne Tourigny wrote:
>> sometimes with on-the fly reprojection enabled, I get a very large
>> number of popups with the message "forward transformation of ...
>> failed with error : latitude or longitude exceeded limits".
> Known problem (you are probably using valuetool), see
> http://hub.qgis.org/issues/4905
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
