[Qgis-developer] popups informing that transformation failed
should happen once, not for each point
Tim Sutton
lists at linfiniti.com
Fri Feb 10 14:27:56 EST 2012
Hi
On Fri, Feb 10, 2012 at 6:36 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Sorry - I should have checked.
> A more general question : what is the status of Master WRT plugin
> support? I have been holding off updating my QGis installation from
> master because but I don't want things to break, especially plugins
> because of API changes.
I havent noticed any broken plugins yet (though I dont use a massive
range of plugins).
Regards
Tim
> regards,
> Etienne
> On Fri, Feb 10, 2012 at 12:43 PM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Etienne,
>> On Fri, 10. Feb 2012 at 11:32:16 -0200, Etienne Tourigny wrote:
>>> sometimes with on-the fly reprojection enabled, I get a very large
>>> number of popups with the message "forward transformation of ...
>>> failed with error : latitude or longitude exceeded limits".
>> Known problem (you are probably using valuetool), see
>> http://hub.qgis.org/issues/4905
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
