[Qgis-developer] Plugin development from amateur...
Alex Mandel
tech_dev at wildintellect.com
Tue Mar 6 19:57:37 EST 2012
You can start by emailing the original author. If you don't get a
satisfactory response follow the same procedure as the previous person
and upload your plugin to http://plugins.qgis.org/ and possibly create a
project for it on http://hub.qgis.org
There are a few questions I'm not sure about:
Should the name be changed so both plugins can exist side by side?
How long should one wait before circumventing the original author if
they don't respond?
Thanks,
Alex
On 03/06/2012 08:26 AM, Thomas Wahlmüller wrote:
> Hi
> At the moment I am also working on upgrading a python plugin (Colour
> scale bar by bc-consult). Only a little testing is left and no changes
> to the user interface are made. Now the plugin should support linear
> interpolation (interpolates to ~200 color values if there are less than
> 100 colors specified) and treat exact styles like discrete styles
> without interpolation.
> The question is: should i make a new Plugin-Project or is there a way to
> update the old one for me. Or is it better to send the code to one which
> updates the plugin?
> best whishes
> thomas
> Am 06.03.2012 16:27, schrieb Patrice VERCHERE:
>> Hello,
>> First, sorry for my english
>> Second :
>> I've upgraded the python plugin made by Mr Jurgiel "Profile", witch is
>> now able to work with polyline, with on the fly projection of raster,
>> and with multi-band raster. I'm "amateur" developer, and i think i'm
>> quite representative of people who don't know so much about
>> development, but want humbly to contribute ...
>> I wanted to join Mr Jurgiel to see if there's a place (like git..)
>> where i can find and modify the source. but i found nothing.
>> Then, readinq qgis web pages, i learned that there is the site
>> "http://plugins.qgis.org/" where plugin can be shared. I registered
>> and shared the plugin.
>> also, i decided to create a project under
>> http://hub.qgis.org/projects/qgis-user-plugins, as recommended
>> So, i've got some questions and remarks :
>> - If Mr Jurgiel see my post, does he let me the right to share the
>> plugin, whitch is under GNU LGPL ? (Do i need his agreement? - there's
>> a copyright with his name on the top of .py code, what does it involve ?)
>> - How do i know that the plugin is validated on
>> http://plugins.qgis.org/ ? And if he's not, how do i know why ?
>> I think that de validation procedure is quite complicated, everybody
>> should put a plugin on http://plugins.qgis.org/. Maybe enabling
>> comments about the plugin on this page should be a good way to :
>> -know if the plugin is good or not,
>> -simply have remarks about the plugin, without opening the tracker
>> procedures. That is simplier for lot of people.
>> -Then, creating a project on
>> http://hub.qgis.org/projects/qgis-user-plugins, i didn't succeed in
>> creating project within the qgis-user-plugins
>> <http://hub.qgis.org/projects/qgis-user-plugins> projet. is it normal
>> ? I 've read that the admin of the site is moving plugin ? Also, how
>> enabling maximum of people to contribute on this plugin ?
>> To conclude, i'm not a pro, but i have good intentions. if the basic
>> procedure is explained on http://plugins.qgis.org/, some points are
>> not explained, and amateur like me could be quite lost :
>> how do i know if the plugin shared is validated ? how long does it
>> take ? and if not validated, why ?
>> how do i create a project within qgis-user-plugins
>> <http://hub.qgis.org/projects/qgis-user-plugins> project ?
>> thank you for your attention and your answers,
>> Patrice, France
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
