[Qgis-developer] gsoc 2012
G. Allegri
giohappy at gmail.com
Wed Mar 21 11:28:50 EDT 2012
Wow Victor! I was thinking about it since a month... and it's already
there!
I'm already inside the GC svn to see the nice things you produced ;)
Thanks!
giovanni
2012/3/21 Victor Olaya <volayaf at gmail.com>
> Just a quick comment that might be interesting related to that topic.
> I am about to release the first version of the SEXTANTE platform for
> QGIS. It contains a toolbox, a graphical modeler, script creator
> (creation of new algorithms from scripts), a batch processing
> interface, history, and much more. It currently supports SAGA, GRASS
> and R algorithm (R scripts), and I have also added some built-in QGIS
> processes (the ftools ones and the mmqgis ones). Creation of new
> algorithms and new providers it is rather easy.
> If you are familiar with the SEXTANTE processing framework, it is
> basically the same thing, with some added new things and improvements.
> I wanted to wait a bit more until it is more or less stable, but since
> I see some action in the QGIS processing area, I think it is worth
> mentioning it now, so you can consider it.
> Anyway, for those interested, source code of the QGIS SEXTANTE plugin
> is available in the SEXTANTE SVN at googlecode, and as I said, a first
> version will probably be released soon. A help manual is also almost
> finished, with around 40 pages describing the framework
> Regards
> El día 21 de marzo de 2012 15:15, Paolo Cavallini
> <cavallini at faunalia.it> escribió:
> > Il 21/03/2012 12:59, Alexander Bruy ha scritto:
> >> So, the idea is to extend ProcessingFramework with new
> >> backends, with main focus on HPGL library [0] which is
> >> very handy for analysis. Also this work may include other
> >> backends, for example GDAL.
> >> Any opinions and comments?
> > I think, the more backends the better. However, there is still some
> > important work to be done on the framework itself, as Martin has pointed
> > out.
> > Please consider also the availability of packages for the backend for all
> > major platforms, as this has proved to be a serious hindrance.
> > All the best.
> > Paolo Cavallini
> > See: http://www.faunalia.it/pc
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120321/464099a4/attachment.html
