[Qgis-developer] Approving plugins
Paolo Cavallini
cavallini at faunalia.it
Tue May 15 01:29:48 PDT 2012
Il 11/05/2012 14:56, kimaidou ha scritto:
> For these reasons I think we should not force developpers to add test data :
> * it increases the sise of the zip
> * some plugins won't need specific data to be tested
> * We can instead ask which data in the Alaska sample data can be used to test the
> plugin ?
I think sample data should be added only if the plugin requires them. For instance,
it is difficult to check the usage of Time Manager without properly designed data. On
the other hand, mosst drawing plugins need no data.
So we should be flexible.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
