[Qgis-developer] from qgis.core impor * Windows problems
G. Allegri giohappy at gmail.com
Thu May 24 10:00:41 PDT 2012
Right Jurgen, I meant qgis.bat.
2012/5/24 Jürgen E. <jef at norbit.de>
> Hi Giovanni,
> On Thu, 24. May 2012 at 17:15:58 +0200, G. Allegri wrote:
> >    are you using osgeo4w? In that case I suggest you to have a look to
> the
> >    startup .bat files (like C:\OSGeo4W\OSGeo4W.bat), that setup the right
> >    evnironment (python pat, bin dires, etc.)
> You can install and use both qgis or qgis-dev, therefore qgis isn't address
> generally in OSGeo4W(.bat).
> Start from %OSGEO4W_ROOT%\bin\qgis.bat or %OSGEO4W_ROOT%\bin\qgis-dev.bat,
> which sets up the environment for the particular version and starts QGIS.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120524/922f953d/attachment.html
