[Qgis-developer] String freeze and call for final translation updates
Alister Hood
Alister.Hood at synergine.com
Sun May 27 17:10:27 PDT 2012
Hi again,
> > From: Giovanni Manghi [mailto:giovanni.manghi at faunalia.pt]
> > Sent: Monday, 28 May 2012 11:50 a.m.
> > To: Alister Hood
> > Cc: qgis-developer at lists.osgeo.org
> > Subject: Re: [Qgis-developer] String freeze and call for final translation
> > updates
> > Hi,
> > > Maybe you wouldn't technically classify it as a regression, but if I
> > > remember correctly, the list of "Recently used" CRSs is a new feature in
> > 1.8, and a fairly serious bug has been introduced with it:
> > > http://hub.qgis.org/issues/5030#note-5
> > it is just my opinion, but I don't see this as a blocker but certainly
> > something to be fixed.
> > If you enter the "set layer crs" dialog is because you want to change the
> > CRS to the layer.
This is not a safe assumption.
> > If the crs you need is not listed in the "recently used
> > CRSs" then you have the filter. If you click "cancel" the CRS is not
> > changed regardless what was selected.
I've replied on the tracker if anyone wants to follow it.
Alister
