[Qgis-developer] Build question for 1.8
Larry Shaffer
larrys at dakotacarto.com
Mon May 28 15:52:57 PDT 2012
William, et al.,
On Sun, Apr 29, 2012 at 7:04 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote [0]:
> Yes, spatialindex was remove from the source, so it's now an external
> dependency.
> Once found, I see another problem - internally, spatialindex headers
> include each other by spatialindex/*/*.h. But QGIS does not - I think it's
> previous internal spatialindex had these includes all changed. ...and
> indeed, changing the one include in core/qgsspatialindex.cpp to:
> #include <spatialindex/SpatialIndex.h>
> does the trick.
Manual edit of core/qgsspatialindex.cpp still required for building on Mac.
Should that change be considered, or should the edit just be noted in the
Mac build notes?
Regards,
Larry
[0]
http://osgeo-org.1560.n6.nabble.com/Config-fails-on-find-of-spatialindex-library-tp4939392p4939734.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120528/7186c7c0/attachment.html>
