[Qgis-developer] plugin builder quantumgis
Filipe Brandão fgbrandao at emepc-portugal.org
Mon Nov 12 04:58:00 PST 2012
Thanks Ed.
had a few other problems such as an error that stated something like no
resources_rc module.
Tried out a few things and at the end changed the file resources.py to
resoruces_rc.py and everything seems to be running smoothly...
Is this normal? Am I doing something completely non sense?
Thanks,
Filipe
On Fri, Nov 9, 2012 at 7:29 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
> Filipe****
> You need to install "Make for Windows",
> http://gnuwin32.sourceforge.net/packages/make.htm.  Once "Make for
> Windows" is installed, you will be able to use the make file by opening the
> command line, navigate to your plugin folder and then issue the make
> command.  There is a very good tutorial at
> http://www.qgisworkshop.org/html/workshop/index.html, although the
> tutorial is using a Linux virtual machine.  If you are considering
> developing GUI you may also want to install PyQt at
> http://www.riverbankcomputing.com/software/pyqt/download.****
> Ed****
> *From:* qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] *On Behalf Of *Filipe Brandão
> *Sent:* Friday, November 09, 2012 12:08 PM
> *To:* qgis-developer at lists.osgeo.org
> *Subject:* [Qgis-developer] plugin builder quantumgis****
> Hi all
> I'm writing because of a problem I'm facing regarding quantumgis plugin
> builder.
> First of all, I'm working on windows 7.
> Followed the instruction on the link
> http://www.qgis.org/pyqgis-cookbook/plugins.html
> More precisely on the bottom of the page:
> Remark: Configuring Your IDE on Windows****
> Installed quantumgis using the OsGeo4w release, pyscripter and the plugin
> buider.****
> After running the plugin builder, an image shows up telling us what to do.
> The problem is that i don't even have a clue on what this means.****
> Compile the ui file using pyuic4****
> Compile the resources file using pyrcc4
> Sorry for my ignorance but I'm trying to initiate my self on quantumgis
> python development and I'm completely stuck here.
> Thanks in advance
> *Filipe *****
*Filipe Brandão
Gabinete de Geomática
E-mail: fgbrandao at emepc-portugal.org <fgbrandao at am-em.org>
Ext. interna: 204176
Estrutura de Missão para a Extensão da Plataforma Continental / Task Group
for the Extension of the Portuguese Continental Shelf
http://www.emam.com.pt/
Rua Costa Pinto 165,
2770-047 Paço de Arcos, Portugal
Telefone: 213 804 250, 213 004 165 Fax: 213 905 225
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121112/556464a8/attachment.html>
