[Qgis-developer] Keeping up with latest Sextante developments
Rudi von Staden rudivs at gmail.com
Sat Oct 27 05:20:32 PDT 2012
Hi all,
There's quite a bit of activity on the Sextante plugin, and I'd like to
keep up with the latest developments. It seems things have changed recently
so I have a couple of questions about the best approach:
1) As far as I can tell, active development is now happening on GitHub QGIS
core rather than svn; if I fork the QGIS repo, can I use just the sextante
plugin with old faithful QGIS 1.8.0, or could I run into conflicts?
2) I am encountering quite a few bugs which are relatively easy to fix. If
I do so, should I log them on hub.qgis.org and supply a patch, or is it
better to initiate a pull request on GitHub?
Thanks,
Rudi
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121027/2b7c1ce2/attachment.html>
