[Qgis-developer] Keeping up with latest Sextante developments
Alexander Bruy
alexander.bruy at gmail.com
Sat Oct 27 05:26:37 PDT 2012
2012/10/27 Rudi von Staden <rudivs at gmail.com>:
> 1) As far as I can tell, active development is now happening on GitHub QGIS
> core rather than svn; if I fork the QGIS repo, can I use just the sextante
> plugin with old faithful QGIS 1.8.0, or could I run into conflicts?
Yes, you can use SEXTANTE from core with older QGIS versions.
> 2) I am encountering quite a few bugs which are relatively easy to fix. If I
> do so, should I log them on hub.qgis.org and supply a patch, or is it better
> to initiate a pull request on GitHub?
Better to issue pull request with bug description. But also you can
create ticket
and add link to pull request in it.
Alexander Bruy
