[Qgis-developer] New Vector API
Ivan Mincik ivan.mincik at gmail.com
Tue Apr 2 11:58:33 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 04/02/2013 03:10 PM, Matthias Kuhn wrote:
> Hi Martin, hi List
> On 04.01.2013 22:19, Martin Dobias wrote:
>> Hi Matthias
>> thanks for your mail.
>> On Thu, Jan 3, 2013 at 10:37 AM, Matthias Kuhn <matthias.kuhn at gmx.ch>
wrote:
>>> You've been talking about updating to PyQt4 SIP version 2. I noticed
this
>>> change did not yet happen. What are your plans regarding this update?
>> Yes, the plans are still there. I'm only wondering what would be the
>> best time to switch - right now within the branch or a bit later once
>> the branch is merged and the new code settles down a bit? I can see a
>> slight advantage of the latter approach of having a greater chance of
>> separating problems caused by the merge and problems caused by the SIP
>> API change, but I do not have a strong opinion here.
> Despite feature freeze, I'd like to ask what happened to that plan. As
> far as I know, this change has not been made, and if this change is not
> made before QGIS 2.0 it will have to wait for 3.0 (This is not something
> to be done for 2.1).
> It will probably be a small change (to switch in the core) but with a
> huge impace (concerning plugins).
I would also vote to switch now when API is broken.
Ivan Mincik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with undefined - http://www.enigmail.net/
iQEcBAEBAgAGBQJRWypZAAoJEPfdLsR5UpoeXIMIAKw/IIaDGdRGlF8Q2tKpbvnR
VrjteXlFQB+u2g+X6DCgSnbQKUEdpS+HflFJjVVNcTIUMOarMx0qn8nMe8MUiSVE
C/IpKvysW4FlF/bhSdpER/yj42oVNBfzcc+eX6rfZl3qNoidNGN6U+2hvpMDKLX0
oPr6YqPUNwjj9L+MlaV70jBM3kZSPs9dBx9cvktBZeXWH0n9iJpB4vpsSgb6SwDa
CYL6IJZSwCohVdQ7pWOUnb0eQ/Te2GKx9sv22Tlh1rahr7VBWBrKCXssyrkDNiDL
ZjACCof+DxkUOGASDOpFCVbLQDWZsbC2s6eeZxlXNNswycxGch+p2idKeozPluA=
=spqX
-----END PGP SIGNATURE-----
