[Qgis-developer] Qgis-developer Digest, Vol 90, Issue 72
Andrea Peri aperi2007 at gmail.com
Wed Apr 17 06:13:43 PDT 2013
I don't know how worked the old unique-value on old-simbology.
Bat I guess it quite hard in the rule-rendering reproduce the
"other not otherwise defined values". Surely not impossible, ma quite
harder almost manually write it.
Infact every rule is filtered indipendently from other values on the
datasource.
In a rule-render is easy to write a rule like "every value",
but to reply the "otherwise" is necessary to create a filtered rule tha has
every other definided value.
So as example:
if i put:
rule 1)  value = "0101"
rule 2( value = "0102"
rule 3) value = "0103"
...etc...
the "otherwise" condition in the rule-render should be something like:
(value <>"0101") and (value <> "0102") and (value <> "0103") and (value <>
"0104") ...etc....
Andrea.
Date: Wed, 17 Apr 2013 13:34:00 +0200
> From: Anita Graser <anitagraser at gmx.at>
> To: qgis-user at lists.osgeo.org, qgis-dev
>         <qgis-developer at lists.osgeo.org>
> Subject: Re: [Qgis-developer] [Qgis-user] How define the "other"
>         condition on a classification render
> Message-ID:
>         <CAFFV8Fjf-nYiPebYMSDQ4znyhOzZXGXDmQtvBqO5kig=
> hw7n8g at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Wouldn't it make sense to translate  the old style into a rule-based
> renderer? There it's easy to define a style for "other".
> Best wishes,
> Anita
> > qwerty ?????
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130417/71582443/attachment.html>
