[Qgis-developer] sextante: missing GRASS pan sharpening function (i.fusion.brovey)
Mathieu Pellerin
nirvn.asia at gmail.com
Mon Apr 22 00:19:16 PDT 2013
Paolo, nice, didn't know it was that easy to add new functions.
I gave it a go, but something's wrong as the output raster isn't
created. It might have to do with the fact that i.fusion.brovey
doesn't seem to have a raster's output parameter. Instead, and
somewhat unique to this i. function, it has an outputprefix parameter
(see http://grass.osgeo.org/grass64/manuals/i.fusion.brovey.html).
I've tried to simply use that parameter as a placeholder for
sextante's OutputRaster syntax, but it doesn't seem to work.
Victor, do you know what's happening here? Here's the
i.fusion.brovey.txt syntax being used (and failing ATM):
i.fusion.brovey
i.fusion.brovey - Brovey transform to merge multispectral and high-res
panchromatic channels.
Imagery (i.*)
ParameterRaster|ms1|Name of input raster map (green: tm2 / qbird_green
/ spot1)|False
ParameterRaster|ms2|Name of input raster map (NIR: tm4 / qbird_nir /
spot2)|False
ParameterRaster|ms3|Name of input raster map (MIR; tm5 / qbird_red /
spot3)|False
ParameterRaster|pan|Name of input raster map (etmpan / qbird_pan /
spotpan)|False
ParameterBoolean|-l|LANDSAT sensor|False
ParameterBoolean|-q|QuickBird sensor|False
ParameterBoolean|-s|SPOT sensor|False
OutputRaster|outputprefix|Prefix of output raster |False
Math
On Mon, Apr 22, 2013 at 12:01 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 22/04/2013 04:31, Mathieu Pellerin ha scritto:
>> Victor,
>> Would it be possible for you to add GRASS' pan sharpening function
>> (i.fusion.brovey) to sextante? I'm sure that'll make more than one guy
>> happy :)
>> Keep up the good work, lots of very nice tweaks to sextante lately.
> Hi Mathieu,
> please have a look to:
> https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/sextante/grass/grass.txt
> It is reasonably easy to add command yourself. If successful, you can send the file
> to Victor, or better issue a pull request for it.
> Thanks!
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlF0xD0ACgkQ/NedwLUzIr7eQACeNZp1Zb7N+3CqsUZmDz0YKCBG
> b1QAnRZX645dJOGRIhZYwlfzPy/CU8aO
> =7wPK
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
