[Qgis-developer] Several errors
Sanghee Shin endofcap at gmail.com
Thu Feb 14 21:57:52 PST 2013
I wanna close my ticket however I don't think I have enough privileges.
Anybody who has enough privileges, please close my ticket http://hub.qgis.org/issues/6820.
And I'll check more what caused the failure of crssync during post-installation process.
Thanks.
Sanghee
2013. 2. 13., 오후 3:17, Andre Joost <andre+joost at nurfuerspam.de> 작성:
> Am 13.02.2013 05:25, schrieb Sanghee Shin:
>> I prepared new clean windows and installed master version there.
>> Finally I found that srs.db was successfully updated and got all SRSs
>> that I needed.
>> I assume that old environment settings like path&  others from old
>> QGIS or other FOSS4G affected the post-installation process.
>> Do I need to cancel the ticket?
> Maybe it is better to close that, and open another for the installer fault.
>>> Windows : Synchronizing CRS database with GDAL/PROJ definitions.
>>> Could not open database:
>>> C:/Programme/OSGeo4W/apps/qgis-dev/./resources/srs.db [unable to
>>> open database file]
> This is definitely the wrong path. I wonder how you got the C:\Programme\ in there. Thats the german language folder name for Windows XP C:\Program Data\
> For OSGeo4w setup, it should be C:\Osgeo4W\
> Greetings,
> André Joost
> Qgis-developer mailing list
