[Qgis-developer] Attribute Editor: Dual View
Matthias Kuhn
matthias.kuhn at gmx.ch
Wed Jan 9 04:08:28 PST 2013
On 01/09/2013 12:53 PM, Nathan Woodrow wrote:
> On Wed, Jan 9, 2013 at 9:51 PM, Matthias Kuhn <matthias.kuhn at gmx.ch
> <mailto:matthias.kuhn at gmx.ch>> wrote:
> We did not agree on a particular behavior in this case so far. My
> idea is, to open a dual view window as well (with a filter applied
> that matches only the current selection or a sorting, so the
> selection appears on top). Multi edit could then be easily based
> on this.
> I'm not sure that would work IMO. If we have a large layer and it
> needs to load everything before you get the form that would be bad. I
> think it would be best that the filter is really just a fake string
> but the forms is pre-loaded with only the features you selected. If
> the user changes the filter at all then you can reload the table.
I will keep an eye on performance in this special case.
Matthias
> - Nathan
