[Qgis-developer] State of QGIS WFS provider
rldhont
rldhont at gmail.com
Thu Jan 31 01:28:37 PST 2013
There is also a GML2 parser in the QgsGeometry Class. The method is
fromGML2 and is static.
Le 31/01/2013 10:24, Radim Blazek a écrit :
> On Thu, Jan 31, 2013 at 7:41 AM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
>> What peoples thoughts about the state of this provider. The currently
>> limitations I see currently with it is:
>> poor handling of larges datasets (e.g http://hub.qgis.org/issues/4604)
>> doesn't support WFS 1.1 or WFS 2.0 (or GML payloads that go along with those
>> versions)
>> doesn't support setSubsetString.
>> poor operator support for filters e.g no LIKE or spatial stuff
>> Doesn't query GetCapabilities to determine supported functions or operators.
>> Poor user connection UI (i have a patch to improve this to using
>> QSortFilterProxyModel)
>> I wondering if one way to deal to a lot of these issues is to use the OGR
>> WFS implementation with QGIS. As of OGR 1.9 its support for WFS is very
>> good. Benefits are:
>> common code (worked on by more people)
>> handles filters better
>> handles talking to different implementations of the standards better (e.g
>> mapserver, Geoserver, deegree)
>> handles fetching larger datasets better e.g with paging support etc
>> Of course continuing to develop the current driver has the advantage of
>> tighter integration with the QT framework and QGIS. Such as utilising QT
>> network and proxy management.
> Just a note, not directly related to WFS. I am extending QgsWFSData
> (GML parser) to be used for WMS GetFeatureInfo in GML format. The
> changes are not targeted on performance however (getting schema from
> XSD, guessing schema from GML). Just to say that there will be another
> provider using the parser.
> Radim
>> Cheers,
>> Jeremy
>> ________________________________
>> This message contains information, which is confidential and may be subject
>> to legal privilege. If you are not the intended recipient, you must not
>> peruse, use, disseminate, distribute or copy this message. If you have
>> received this message in error, please notify us immediately (Phone 0800 665
>> 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no
>> responsibility for changes to this email, or for any attachments, after its
>> transmission from LINZ. Thank You.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
