[Qgis-developer] State of QGIS WFS provider
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu Jan 31 11:08:22 PST 2013
Hi Jeremy
> doesn't support setSubsetString.
> poor operator support for filters e.g no LIKE or spatial stuff
This is not a general limitation of the WFS provider. There is the
possibility of writing the filter xml into the filter dialog as a string
if needed. I know, it is not very comfortable. But does the OGR driver
come with a better GUI?
>Of course continuing to develop the current driver has the advantage of tighter integration with the QT
framework and >QGIS. Such as utilising QT network and proxy management.
I'd add to that list the possibility of aborting long requests and
receiving status updates (progress bar if server provides total, number
of incoming bytes if not).
In my opinion, it is definitely worth to have a native provider. Support
for GML2 is already in QgsGeometry and there is no reason why not adding
GML3 too.
Regards,
Marco
Am 31.01.2013 07:41, schrieb Jeremy Palmer:
> What peoples thoughts about the state of this provider. The currently
> limitations I see currently with it is:
> poor handling of larges datasets (e.g http://hub.qgis.org/issues/4604)
> doesn't support WFS 1.1 or WFS 2.0 (or GML payloads that go along with
> those versions)
> Doesn't query GetCapabilities to determine supported functions or
> operators.
> Poor user connection UI (i have a patch to improve this to using
> QSortFilterProxyModel)
> I wondering if one way to deal to a lot of these issues is to use the
> OGR WFS implementation with QGIS. As of OGR 1.9 its support for WFS is
> very good. Benefits are:
> common code (worked on by more people)
> handles filters better
> handles talking to different implementations of the standards better
> (e.g mapserver, Geoserver, deegree)
> handles fetching larger datasets better e.g with paging support etc
> of tighter integration with the QT framework and QGIS. Such as
> Cheers,
> Jeremy
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you
> must not peruse, use, disseminate, distribute or copy this message. If
> you have received this message in error, please notify us immediately
> (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original
> message. LINZ accepts no responsibility for changes to this email, or
> for any attachments, after its transmission from LINZ. Thank You.
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130131/a2ecb1fc/attachment.html>
