[Qgis-developer] CyberTracker integration
Agustin Lobo alobolistas at gmail.com
Tue Jul 9 10:19:27 PDT 2013
Hi Justin, I'm using both programs (well, actually, just starting with
cybertracker)
(I'm the one who collaborated to solvve the problem of running CT on Mac)
I think you should keep CT as simple as possible, not only because of
the low-literate users but also because in the field
you want to have what you need and only what you need. The CT approach
in which you design your own template is very good.
What I can see as an advantage is an efficient way of trasnfering the
info collected with CT to Qgis, perhaps through a spatialite object
or some other open spatial database. But I would not add gis capabilites to CT.
Regarding the ability of having more mapping capabilities in the
field, I wonder if you could make use of Oruxmaps, it
works very well on Android, I use it a lot in the field and for
navigating the aerial campaigns.
Agus
On Mon, Jul 8, 2013 at 5:14 PM, Justin Steventon <justin at steventon.com> wrote:
> Hi Antonio,
> One area of difference with CyberTracker is that it captures data as
> name+value pairs. Converting to shape file attributes therefore tends to be
> lossy. Alternatively, one data set point might be able to populate several
> shape file attributes. I’m not sure how to deal with this yet, but my
> thinking is that we would go simple and fully automatic first. The
> integration involves converting a shape to a data model, sending the data
> model to CyberTracker and managing the return of the data.
> For the purposes of analysis, I’m thinking that any feature that
> CyberTracker has that is not in QGIS yet, would be built in parallel over
> time. We have relatively simple charts (like effort, distance travelled,
> etc), but also something called Index of Abundance which would be nice to
> have open (if it’s not already there).
> Cheers,
> -Justin
> From: Antonio Locandro [mailto:antoniolocandro at hotmail.com]
> Sent: Sunday, July 7, 2013 9:13 PM
> To: Justin Steventon
> Cc: qgis-developer at lists.osgeo.org
> Subject: RE: [Qgis-developer] CyberTracker integration
> Thats understandable the differences, now Justin can you specify more about
> how would you like to make the integration
> I am thinking you would probably want to do the data collection using
> CyberTracker, then export it or download it to be used within QGIS. Now what
> is it that you would want to do with the data inside QGIS? Depending on your
> goals you may want to create a plugin that would take the data and do
> certain predefined analysis
> Regards
> Antonio Locandro
> ________________________________
> From: justin at steventon.com
> To: antoniolocandro at hotmail.com; madmanwoo at gmail.com
> CC: qgis-developer at lists.osgeo.org
> Date: Sun, 7 Jul 2013 13:47:37 -0700
> Hi Antonio,
> Yes, similar to Fulcrum.
> I’ve been following them for a while now and think they are doing a lot of
> things right. They’re missing a few components that are important for us,
> e.g. full offline (for security) and support for a number of in-field
> scenarios. It’s possible these features will be created over time. The
> proprietary nature of Fulcrum would tend to turn off some potential groups
> in the same way as it occasionally has for us.
> So far, we have not seen meaningful support for low literate users in any
> major product. As more and more folks have smart phones, this may pick up.
> Cheers,
> -Justin
> Sent: Sunday, July 7, 2013 8:54 AM
> To: Justin Steventon; 'Nathan Woodrow'
> Hi Justin
> I think your project seems a little bit similar to http://fulcrumapp.com/
> http://fulcrumapp.com/features/  for field data collection, maybe just
> missing the part for people who can read or write
> What they do is capture data using custom forms on the field and then you
> sync over the internet on the cloud, once on a computer you can export the
> data to use with GIS software and create PDF reports
> Probably a similar approach?
> Antonio Locandro
> To: madmanwoo at gmail.com
> Date: Sat, 6 Jul 2013 23:07:25 -0700
> Subject: Re: [Qgis-developer] CyberTracker integration
> That’s true, I missed the concept of a form in the description on the site.
> My interest is in a rich, user friendly data capture experience, especially
> for cases where the field user is not a QGIS user and may not be able to
> read or write. Our studies indicate that this is also a more efficient way
> to capture data for literate users. Over the years we’ve rolled our own
> mini-GIS for the desktop, but the scalability of this approach is clearly
> limited. Since we’re a non-profit and in the process of opening our code, it
> makes sense to leverage an existing system. Of the solutions I have
> investigated, QGIS seems most aligned at the technical level.
> We do bring some interesting work to the table. Our client supports Windows
> Mobile and Android and has a large library of customizable UI components
> which can capture many different data types, including images and sound.
> There is also support for timer tracks and a field map.
> I’m pretty new to the Open Source community, so apologies if this is off.
> I’m probably going about this all wrong.
> Cheers,
> -Justin
> From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> Sent: Saturday, July 6, 2013 10:24 PM
> My project isn't about putting QGIS onto PDA.  QGIS doesn't run on PDAs and
> I doubt it ever will.
> QMap is meant to be a field collection version of QGIS.
> - Nathan
> On Sun, Jul 7, 2013 at 3:13 PM, Justin Steventon <justin at steventon.com>
> wrote:
> Thanks Jürgen,
> I see Nathan’s project is really about putting a stripped down version of
> QGIS onto a PDA. Nevertheless, it’s impressive.
> CyberTracker is designed more as a data capture conduit – highly
> customizable UI (via XML) that can be used even by low-literate folks.
> Integration with QGIS would be great.
> If anyone is interested in a collaboration, please let me know.
> Cheers,
> -Justin
> Qgis-developer mailing list
> _______________________________________________ Qgis-developer mailing list
