[Qgis-developer] Raster tools support for GDAL 1.10 in QGIS 2?
Etienne Tourigny
etourigny.dev at gmail.com
Thu Jul 18 10:32:05 PDT 2013
There are probably a number of options that are not recognized due tho this
bug, which has been partially fixed.
Can you please file a generic bug report and add any other missing elements?
cheers
Etienne
On Thu, Jul 18, 2013 at 1:45 PM, Cline, Royce L. <rcline at nd.gov> wrote:
> Is the intent to have the GDAL tools in the Raster menu support using GDAL
> 1.10 with the release of QGIS 2. With QGIS 2 built with GDAL 1.10, the
> "Mask layer" radio button does not display in the Clipper dialog. GDAL 1.10
> is failing the the version test in doClipper.py as it thinks 1.10 is older
> than 1.7. I would assume other tools may also be effected. Should I file a
> bug report? Priority?
> Royce
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130718/b8109081/attachment-0001.html>
