[Qgis-developer] Raster tools support for GDAL 1.10 in QGIS 2?
Cline, Royce L.
rcline at nd.gov
Thu Jul 18 12:17:35 PDT 2013
Done in bug report #8323.
Royce
On Jul 18, 2013, at 12:32 PM, Etienne Tourigny <etourigny.dev at gmail.com<mailto:etourigny.dev at gmail.com>> wrote:
There are probably a number of options that are not recognized due tho this bug, which has been partially fixed.
Can you please file a generic bug report and add any other missing elements?
cheers
Etienne
On Thu, Jul 18, 2013 at 1:45 PM, Cline, Royce L. <rcline at nd.gov<mailto:rcline at nd.gov>> wrote:
Is the intent to have the GDAL tools in the Raster menu support using GDAL 1.10 with the release of QGIS 2. With QGIS 2 built with GDAL 1.10, the "Mask layer" radio button does not display in the Clipper dialog. GDAL 1.10 is failing the the version test in doClipper.py as it thinks 1.10 is older than 1.7. I would assume other tools may also be effected. Should I file a bug report? Priority?
Royce
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130718/6121de10/attachment.html>
