[Qgis-developer] QGIS compilation in Linux
Etienne Tourigny etourigny.dev at gmail.com
Fri Jul 26 08:52:48 PDT 2013
On Thu, Jul 25, 2013 at 1:44 AM, <agadisugandha at bel.co.in> wrote:
> Hi All,
>         Im compiling the Qgis1.8 in RHEL 5, all the dependencies I have
> compiled, so now compiling the source code of QGIS, while doing
> that as per compilation instruction when I gave "ccmake ..",
> everything went properly but when I gave option 'g', it is showing
> some WARNING messages like:
> WARNING: Target "qgis_core" requests linking to directory
> "/usr/local/lib".  Targets may link only
>  to libraries.  CMake is dropping the item.
>  WARNING: Target "qgis_analysis" requests linking to directory
>  only to libraries.  CMake is dropping the item.
>  WARNING: Target "qgis_networkanalysis" requests linking to directory
>  link only to libraries.  CMake is dropping the item.  ETC
>         Along with the WARNINGS I gave "make", at that time its giving an
> error like this:
> src/core/qgsexpression.h: In member function ˜virtual QStringList
> QgsExpression::NodeInOperator::referencedColumns() const:
> /root/Desktop/qgis/final_qgis/qgis-1.8.0-9_0.el6.src.rpm_FILES/qgis-1.8.0/src/core/qgsexpression.h:335:
> error: no matching function for call to
> ˜QStringList::append(QStringList)™
> /usr/local/Trolltech/Qt-4.4.0/include/QtCore/qlist.h:420: note: candidates
> are: void QList<T>::append(const T&) [with T = QString]
I have no idea why you get these errors, but you should NEVER run as root
user, unless installing important things.
Try again as a normal user, you will probably have better success.
Etienne
> Please guide me.
> Thanks
> Sugandha
> Every 3000 Sheets of paper costs us a tree.. Save trees... Conserve
> Trees. Don't print this email or any Files unless you really need to!!!!
> Confidentiality Notice
> The information contained in this electronic message and any
> attachments to this message are intended for the exclusive use of
> the addressee(s) and may contain confidential or privileged
> information. If you are not the intended recipient, please notify
> the sender at Bharat Electronics  or support at bel.co.in immediately
> and destroy all copies of this message and any attachments.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130726/a3574f26/attachment.html>
