[Qgis-developer] QGIS compilation in Linux
agadisugandha at bel.co.in agadisugandha at bel.co.in
Fri Jul 26 19:46:01 PDT 2013
    Thank u for the reply. Ya I will try with the normal user only. But
now those warnings are not there but that Qt related errors are still
there. I ll try and inform u sir.
Thanks,
Sugandha
> On Thu, Jul 25, 2013 at 1:44 AM, <agadisugandha at bel.co.in> wrote:
>> Hi All,
>>         Im compiling the Qgis1.8 in RHEL 5, all the dependencies I have
>> compiled, so now compiling the source code of QGIS, while doing
>> that as per compilation instruction when I gave "ccmake ..",
>> everything went properly but when I gave option 'g', it is showing
>> some WARNING messages like:
>> WARNING: Target "qgis_core" requests linking to directory
>> "/usr/local/lib".  Targets may link only
>>  to libraries.  CMake is dropping the item.
>>  WARNING: Target "qgis_analysis" requests linking to directory
>>  only to libraries.  CMake is dropping the item.
>>  WARNING: Target "qgis_networkanalysis" requests linking to directory
>>  link only to libraries.  CMake is dropping the item.  ETC
>>         Along with the WARNINGS I gave "make", at that time its giving
>> an
>> error like this:
>> src/core/qgsexpression.h: In member function ˜virtual QStringList
>> QgsExpression::NodeInOperator::referencedColumns() const:
>> /root/Desktop/qgis/final_qgis/qgis-1.8.0-9_0.el6.src.rpm_FILES/qgis-1.8.0/src/core/qgsexpression.h:335:
>> error: no matching function for call to
>> ˜QStringList::append(QStringList)™
>> /usr/local/Trolltech/Qt-4.4.0/include/QtCore/qlist.h:420: note:
>> candidates
>> are: void QList<T>::append(const T&) [with T = QString]
> I have no idea why you get these errors, but you should NEVER run as root
> user, unless installing important things.
> Try again as a normal user, you will probably have better success.
> Etienne
>> Please guide me.
>> Thanks
>> Sugandha
>> Every 3000 Sheets of paper costs us a tree.. Save trees... Conserve
>> Trees. Don't print this email or any Files unless you really need to!!!!
>> Confidentiality Notice
>> The information contained in this electronic message and any
>> attachments to this message are intended for the exclusive use of
>> the addressee(s) and may contain confidential or privileged
>> information. If you are not the intended recipient, please notify
>> the sender at Bharat Electronics  or support at bel.co.in immediately
>> and destroy all copies of this message and any attachments.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
