[Qgis-developer] QGIS compilation in Linux
Matthias Kuhn
matthias.kuhn at gmx.ch
Sat Jul 27 01:31:43 PDT 2013
Qt 4.4 is really old already. If you are compiling the dependencies
yourself as well as you wrote, you should consider using a newer
version.
Also, I don't know know why you are compiling all the dependencies
yourself, normally it should be enough to install the required -devel
packages.
Regards,
Matthias
On Sam 27 Jul 2013 04:46:01 CEST, agadisugandha at bel.co.in wrote:
> Hi,
> Thank u for the reply. Ya I will try with the normal user only. But
> now those warnings are not there but that Qt related errors are still
> there. I ll try and inform u sir.
> Thanks,
> Sugandha
>> On Thu, Jul 25, 2013 at 1:44 AM, <agadisugandha at bel.co.in> wrote:
>>> Hi All,
>>> Im compiling the Qgis1.8 in RHEL 5, all the dependencies I have
>>> compiled, so now compiling the source code of QGIS, while doing
>>> that as per compilation instruction when I gave "ccmake ..",
>>> everything went properly but when I gave option 'g', it is showing
>>> some WARNING messages like:
>>> WARNING: Target "qgis_core" requests linking to directory
>>> "/usr/local/lib". Targets may link only
>>> to libraries. CMake is dropping the item.
>>> WARNING: Target "qgis_analysis" requests linking to directory
>>> only to libraries. CMake is dropping the item.
>>> WARNING: Target "qgis_networkanalysis" requests linking to directory
>>> link only to libraries. CMake is dropping the item. ETC
>>> Along with the WARNINGS I gave "make", at that time its giving
>>> an
>>> error like this:
>>> src/core/qgsexpression.h: In member function ˜virtual QStringList
>>> QgsExpression::NodeInOperator::referencedColumns() const:
>>> /root/Desktop/qgis/final_qgis/qgis-1.8.0-9_0.el6.src.rpm_FILES/qgis-1.8.0/src/core/qgsexpression.h:335:
>>> error: no matching function for call to
>>> ˜QStringList::append(QStringList)™
>>> /usr/local/Trolltech/Qt-4.4.0/include/QtCore/qlist.h:420: note:
>>> candidates
>>> are: void QList<T>::append(const T&) [with T = QString]
>> I have no idea why you get these errors, but you should NEVER run as root
>> user, unless installing important things.
>> Try again as a normal user, you will probably have better success.
>> Etienne
>>> Please guide me.
>>> Thanks
>>> Sugandha
>>> Every 3000 Sheets of paper costs us a tree.. Save trees... Conserve
>>> Trees. Don't print this email or any Files unless you really need to!!!!
>>> Confidentiality Notice
>>> The information contained in this electronic message and any
>>> attachments to this message are intended for the exclusive use of
>>> the addressee(s) and may contain confidential or privileged
>>> information. If you are not the intended recipient, please notify
>>> the sender at Bharat Electronics or support at bel.co.in immediately
>>> and destroy all copies of this message and any attachments.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
