[Qgis-developer] Labeling of starts and ends of a line
Andreas Neumann a.neumann at carto.net
Tue Mar 5 11:24:35 PST 2013
So this sounds like its not happening any time soon. Definitely after
QGIS 2.0
In this case I will do a helper layer and restrict that line using
linear referencing. My data is in Postgis and I can use its linear
referencing functions.
For the long run I would want to get rid of that helper layer and find a
QGIS only solution.
Thanks for your reply!
Andreas
On 3/5/13 8:13 PM, Martin Dobias wrote:
> Hi Andreas
> On Tue, Mar 5, 2013 at 2:20 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> Maybe Larry, Martin or Marco can answer this:
>> I am looking for the possibility to label a line at the start or end (plus a
>> given offset from start/end). As far as I know this is not yet possible now?
>> Does PAL support this and is it a matter of exposing this option in the GUI
>> or is this not yet supported at all?
> That's not supported as far as I know. It would be handy to have a
> functionality in PAL that would allow us to constrain where the label
> candidates should be created and how they should be prioritized. That
> would also allow us to decide where to put labels for point features
> and which positions are preferred.
> Martin
