[Qgis-developer] New SEXTANTE modeler interface
Victor Olaya volayaf at gmail.com
Tue May 7 02:50:34 PDT 2013
You mean the list of algorithms classified by providers (SAGA, GRASS,
etc)?? The modeler uses the same configuration as the toolbox, so you
should change it in the toolbox. Maybe I shoud add that in the modeler
as well, so it can be changed from there...
I agree that the interface now might be less clear in some cases... Do
you think that it would be interesting to have an option to use the
older modeler?
Thanks!
2013/5/7  <jr.morreale at enoreth.net>:
> Hi Victor,
> I'm testing 1.1, could you tell me how to switch back the modeler to the
> advanced GUI in the modeler ? I've not found a parameter to do so in the
> settings.
> I appreciate that the boxes are now smaller and are directly showing the
> edit/del tools but I found the arrows to be confusing, they're now passing
> behind the boxes and often have to be read from left to right.
> Regards,
> Jean-Roc
> Le 2013-04-24 07:55, Victor Olaya a écrit :
>> Hey guys,
>> I have made some changes to the interface of the modeler, taking into
>> account a couple of suggestions from Tim and Andreas (thanks!). Not a
>> big change, but I guess it's a nice usability improvement.
>> Before starting rewriting the corresponding part in the manual and
>> making new screenshots, I would appreciate if those of you that use
>> SEXTANTE could have a quick look and give me your opinion.
>> Thanks in advance!
>> Víctor
> Qgis-developer mailing list
