[Qgis-developer] QGIS on Ubuntu Tablet
Marco Bernasocchi
marco at bernawebdesign.ch
Thu May 23 12:13:52 PDT 2013
absolutely but I think that the number of ubuntu devices will hardly be as
big as android.
I guess it should just work. well actually it will still require arm
packages no? I have 0 experience with ubuntu on tabs.
the only (hopefully) problem I have left now is that my ubuntu has sip
4.13.3 were the android env has sip 4.10.2 and they have incompatible Api.
I m trying now to downgrade my ubuntu sip. the problem is that sip 4.10.2
requires python 2.6.x
any suggestions?
ciao
Marco Bernasocchi (mobile)
http://opengis.ch
On May 23, 2013 8:38 PM, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
> Hi Marco,
> On Wed, May 22, 2013 at 3:45 PM, Marco Bernasocchi <
> marco at bernawebdesign.ch> wrote:
>> almost there, opefully unmatched sip veesions is the last hurdle.
> Am I to understand that this is directly related to running Python under
> ARM, not necessarily an Adroid issue? The Ubuntu Tablet OS image would be
> replacing Android on the device [0], so maybe some of your troubles with
> the Android API could be entirely bypassed?
> [0] https://wiki.ubuntu.com/Touch/Install
> Regards,
> Larry
>> ciao
>> http://wp.me/p2s3uH-eh
>> http://opengis.ch
>> On May 22, 2013 10:56 PM, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
>>> If you can get QMap running on that platform I would be very interested
>>> to see it. Once Python support is in Android I should be able to cover
>>> that base with QMap.
>>> - Nathan
>>> On Thu, May 23, 2013 at 6:50 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
>>>> Hi,
>>>> Just yesterday I was approached at work about making a mobile gis-based
>>>> field mapping program for dinosaur bone excavations (my current day job is
>>>> IT- and design-related for a professional paleontology company). Of course
>>>> I thought of a QGIS-Android and QMap first. Then, I read about the upcoming
>>>> Ubuntu Tablet (Touch) [0], a replacement for Android on modern tablets
>>>> (e.g. Google Nexus, etc.) currently in development release [1][2].
>>>> As I understand, it is the full OS, with a stripped GUI down using a
>>>> custom version of Unity that allows both desktop and mobile apps to run
>>>> side-by-side, both literally and graphically.
>>>> Has anyone tried this OS on a tablet yet; and, if so, do you have a
>>>> guess on how QGIS might run under it? (I'm looking into a Nexus 10 for
>>>> testing.)
>>>> Marco Bernasocchi, since it appears to be just getting everything to
>>>> compile and run under ARM chip, any thoughts on what may be needed to get
>>>> QGIS up and running under such an OS? I have not found whether Python is
>>>> supported yet, but I anticipate it will be.
>>>> [0] http://www.ubuntu.com/tablet
>>>> [1]
>>>> http://arstechnica.com/gadgets/2013/02/ubuntu-for-tablets-arriving-on-nexus-7-nexus-10-this-week/
>>>> [2] https://wiki.ubuntu.com/Touch
>>>> Regards,
>>>> Larry
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130523/82b86ad5/attachment.html>
