[Qgis-developer] Postgres Audit Trigger plugin: beta-tester & feedback
Denis Rouzaud denis.rouzaud at gmail.com
Sun May 26 23:33:50 PDT 2013
Hi Ivan,
I updated the plugin with your useful comments. You have a version 0.4
available.
Regarding the schema tables names, I have filled a pull request here
<https://github.com/2ndQuadrant/audit-trigger/pull/2>https://github.com/2ndQuadrant/audit-trigger/pull/2/files
You can use my branch if you like:
https://github.com/3nids/audit-trigger/blob/schemasafe/audit.sql
I have an issue tracker on github:
https://github.com/3nids/postgres91plusauditor/issues
Thanks a lot for your comments and for your time at testing, it's really
appreciated! I am waiting for these bugs ;)
Greetings,
Denis
On 05/22/2013 01:53 PM, Ivan Mincik wrote:
> Hi Denis,
> I have found a problem. The problem was that menu item 'Define logged
> action layer' was confusing for me and I was choosing my PostGIS
> geometry layer there. I recommend to rename it to something like
> 'Choose audit history table' (avoid using 'layer') with some
> description that the table should be loaded to QGIS. Now 'search
> history' windows opens correctly.
> Also I recommend to exclude at least any geometry tables from 'logged
> action layer chooser' dialog and also exclude 'history table' from
> choosing itself from selecbox in 'search history' window.
> One more question, how do you activate audit if table exists in some
> schema outside of default search_path ? Using
> SELECT  audit.audit_table('<schema>.<table>');
> is not working for me.
> I have found some other bugs which will be better to submit in bug
> tracker. Do you have some ?
>     I have hesitated with creating something like your approach, but I
>     decided to use something which is "official". As, the trigger is
>     available on postgres website, I hope it will last a bit.
> I see one big disadvantage with this Audit trigger implementation
> which is performance, if history of all tables is recorded to one huge
> table. If you have many changes in one big table it will affect all
> other. Moreover I am missing tests (which of course can be added).
> Thanks,
> Ivan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130527/257054fb/attachment.html>
