[Qgis-developer] How to enable labeling tools to move labels (since last merge of Larry's work)
kimaidou kimaidou at gmail.com
Mon May 27 01:09:21 PDT 2013
Hi
2013/5/27 HAUBOURG <regis.haubourg at eau-adour-garonne.fr>
>  Hi Larry, ****
> Putting expression item to the bottom of list, and renaming the entries as
> follow should be better IMHO, since expression is more advanced:
> “Field types : String, Int, Double”  -> “choose Field ( enable map tools)”
> “Edit expression” ->” Calculate value with expression (disable map tool)”*
> Does that sound good?
This sounds good to me, as I had the same problem easilly finding the way
to choose fields here.
> [0] https://dl.dropboxusercontent.com/u/72368800/label_dialog.png****
> All the best****
> Régis
Regards
Michael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130527/8f50b0ce/attachment.html>
