[Qgis-developer] Build QGIS with QtCreator, LNK2019 error
Zeben M. C.
zebensui at gmail.com
Thu Nov 21 06:58:54 PST 2013
Already fixed,
I changed the setting of "pyconfig.h" for not use the library
"python27_d.lib". But it is also necessary to comment the definition of
Py_DEBUG like this:
# ifdef _DEBUG
/ / # Define Py_DEBUG
# endif
In summary, pyconfig.h:
Changes:
# ifdef _DEBUG
# Define Py_DEBUG
# endif
to
# ifdef _DEBUG
# endif
and
# Ifdef _DEBUG
# Pragma comment (lib, "python24_d.lib")
# else
# Pragma comment (lib, "python24.lib")
# Endif / * _DEBUG * /
to
# Ifdef _DEBUG
# else
Thank you.
2013/11/21 Zeben M. C. <zebensui at gmail.com>
> I'm trying to build QGIS with QtCreator. I am following the instructions
> found in:
> https://github.com/qgis/QGIS/blob/master/CODING (4. Getting up and
> running with QtCreator and QGIS).
> When I build the project (using Jom) always fails with this error:
> Linking CXX shared library ..\output\python\qgis\core.pyd
> Creating library core.lib and object core.exp
> sipcorepart0.cpp.obj : error LNK2019: unresolved external symbol
> __imp___Py_Dealloc referenced in function "class QgsSymbolLayerV2 * __cdecl
> sipVH_core_0(enum PyGILState_STATE,struct _object *,class QDomElement &)"
> (?sipVH_core_0@@YAPAVQgsSymbolLayerV2@@W4PyGILState_STATE@@PAU_object@
> @AAVQDomElement@@@Z)
> sipcorepart1.cpp.obj : error LNK2001: unresolved external symbol
> __imp___Py_Dealloc
> sipcorepart2.cpp.obj : error LNK2001: unresolved external symbol
> __imp___Py_Dealloc
> sipcorepart3.cpp.obj : error LNK2001: unresolved external symbol
> __imp___Py_Dealloc
> __imp___Py_NegativeRefcount referenced in function "class QgsSymbolLayerV2
> * __cdecl sipVH_core_0(enum PyGILState_STATE,struct _object *,class
> QDomElement &)" (?sipVH_core_0@@YAPAVQgsSymbolLayerV2@@W4PyGILState_STATE@
> @PAU_object@@AAVQDomElement@@@Z)
> sipcorepart0.cpp.obj : error LNK2001: unresolved external symbol
> __imp___Py_RefTotal
> __imp___Py_RefTotal
> sipcorepart2.cpp.obj : error LNK2019: unresolved external symbol
> __imp___Py_RefTotal referenced in function
> _meth_QgsComposerTable_horizontalViewScaleFactor
> __imp___Py_RefTotal
> __imp__Py_InitModule4TraceRefs referenced in function _initcore
> ..\output\python\qgis\core.pyd : fatal error LNK1120: 4 unresolved
> externals
> LINK Pass 1 failed. with 1120
> Also, i have several previous warning in the console as:
> - some macro redefinition and
> - or: -1: Warning: LNK4098: defaultlib 'MSVCRT' Conflicts with use of
> other libs; wear / NODEFAULTLIB: library
> Also using NMAKE (instead JOM), it fails. The error take place much later
> in the build but fails.
> I am able to build QGIS using Visual Studio 2008 but with the aim of more
> easily debug, I trying to use QtCreator..
> Any idea?
> My goal is to build a slightly modified version of Qgis able, among other
> things, to create polygons the same way to create rings.
> Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131121/3fa61f94/attachment-0001.html>
