[Qgis-developer] PR1007 bump minimum to 4.7: objections?
Jürgen E. Fischer
jef at norbit.de
Wed Nov 27 02:26:05 PST 2013
Hi Richard,
On Wed, 27. Nov 2013 at 10:25:36 +0100, Richard Duivenvoorde wrote:
> > I don't see a point in this. The pull request will just break the lucid
> > builds without adding anything new (or cleaning out any old code that
> > requires Qt <4.7).
> Ok. Clear. Then we should close the two pull requests with the message: we
> want to provide lucid builds untill .... so before that time we will not
> upgrade Qt...
Apparently not so clear. Lucid is not the point. It that it's just breaking
something w/o achieving anything else. And that's essentially the only thing
it does.
QGIS currently works with earlier versions. That (tiny) change could be part
of a larger PR that removes all the old ifdefed code, that will become useless,
once QGIS refuses to be compiled on Qt <4.7 anyway. Or when something else is
added that requires Qt 4.7 (and which needs some effort to to maintain for Qt
<4.7).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
