[Qgis-developer] PR1007 bump minimum to 4.7: objections?
Sandro Santilli strk at keybit.net
Wed Nov 27 02:43:18 PST 2013
May I ask why this discussion is happening here rather than
on the pull request page ? I'd feel pretty lonely if I was
the contributor of it... :(
--strk;
On Wed, Nov 27, 2013 at 11:26:05AM +0100, Jürgen E. Fischer wrote:
> Hi Richard,
> On Wed, 27. Nov 2013 at 10:25:36 +0100, Richard Duivenvoorde wrote:
> > > I don't see a point in this.  The pull request will just break the lucid
> > > builds without adding anything new (or cleaning out any old code that
> > > requires Qt <4.7).
> > Ok. Clear. Then we should close the two pull requests with the message: we
> > want to provide lucid builds untill .... so before that time we will not
> > upgrade Qt...
> Apparently not so clear.  Lucid is not the point.  It that it's just breaking
> something w/o achieving anything else.  And that's essentially the only thing
> it does.
> QGIS currently works with earlier versions.  That (tiny) change could be part
> of a larger PR that removes all the old ifdefed code, that will become useless,
> once QGIS refuses to be compiled on Qt <4.7 anyway.  Or when something else is
> added that requires Qt 4.7 (and which needs some effort to to maintain for Qt
> <4.7).
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
 ()  ASCII ribbon campaign        - against html e-mail
 /\  http://www.asciiribbon.org   - against proprietary attachments
