[Qgis-developer] Installing Processing problems
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 18 00:08:40 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 18/10/2013 08:43, Paolo Cavallini ha scritto:
> My OS X package has all the Processing dependencies bundled in the app. With a clean
> install it should find the bundled GRASS (and SAGA, OTB, TauDEM) automatically. If
> you have used the 2.0 nightlies before 2.0 release, your preferences may have paths
> to Processing components that don't work with my build. The Processing prefs are not
> stored with the QGIS global prefs, but are in the ~/.qgis2/processing folder. But
> the GRASS path for the GRASS plugin (non-processing), and the flags that say that
> GRASS and SAGA are installed for Processing ARE stored in the global QGIS prefs
> (~/Library/Preferences/org.qgis.qgis2.plist), so you might want to try deleting both.
Hi William,
thanks for clarifying. Apparently the user has a fresh install, so this should not be
the problem. GRASS plugin works, it is just Processing plugin that has trouble
finding it.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlJg3ngACgkQ/NedwLUzIr6brgCePjKlyDNURh0P47z6bFeEPxTh
V2IAnRhmuuEly82O/tClb88rrtGM/35y
=s6CV
-----END PGP SIGNATURE-----
