[Qgis-developer] install instructions
Alex Mandel
tech_dev at wildintellect.com
Mon Sep 30 09:22:48 PDT 2013
On 09/30/2013 07:35 AM, Barry Rowlingson wrote:
> On Sun, Sep 29, 2013 at 8:15 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> Barry - To clarify again, the Ubuntugis version is the same version of
>> QGIS, what differs is GDAL, PROJ and GEOS - by significant version, ie
>> gdal 1.8 vs 1.10
>> This is critical because 1.10.x supports more of the formats people
>> having been asking for like HDF, etc...
> Another annoyance: I can't get SAGA geoprocessing working. I think
> this is because the saga version on ubuntugis-unstable is 2.0.8, but
> QGIS requires 2.1 according to:
> http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html
> Also, those docs mention an option I can't find: the "SAGA Folder"
> setting in the SAGA configuration. Is this supposed to be in the
> Processing/Options and Configuration dialog in QGIS 2.0? - Maybe that
> will either magically appear when I do get SAGA 2.1 installed or its a
> hangover from an earlier QGIS....
> Sorry to bring these up post-release, but I had to upgrade my machine
> first and didn't want to do that before FOSS4G!
> Barry
That's a known packaging issue previous discussed with Johan.
SAGA 2.1 requires newer wxwidgets than 12.04 has (which could also
effect GRASS). He was hesitant to put wxwidgets in Ubuntugis. I think he
was going to ask Victor to make it possible to still use 2.0.8 with
Processing/Sextante, which we do have.
Or you can get it from https://launchpad.net/~johanvdw/+archive/saga-gis
Not sure if it will break GRASS or not.
Last discussion on the topic was on in August.
Thanks,
Alex
