[Qgis-developer] possible vector edit commit bug, please try to reproduce to confirm
Trevor Wiens
tsw.web at gmail.com
Wed Aug 20 06:50:05 PDT 2014
Thanks Bernhard. I did try uninstalling my Python plugins with no effect.
It however should not make any difference because I can recreate the issue
manually which should not be affected by any plugins.
What I've done for my plugin, as I'm already using the pyspatialite
library, is to replace qgis calls with direct writes with the spatialite
library and I don't have any slow down.
It seems to me that something funny is going on with QGIS itself but I
found a work around for my own issue for now.
Thanks again
TSW
On Aug 19, 2014 11:58 PM, "Bernhard Ströbl" <bernhard.stroebl at jena.de>
wrote:
> Hi Trevor,
> just guessing: Is your plugin applying the editingStarted()/editingStopped()
> signals? If not there are plugins around that do it and are known to slow
> down QGIS. So if it is not your plugin first thing would be to unload _all_
> plugins and see if the problem persists. If not reload the plugins only one
> at a time to identify the one causing the problem.
> Bernhard
> Am 20.08.2014 01:42, schrieb Trevor Wiens:
>> I'm working on a QGIS plugin where I need to commit changes every time a
>> new feature is added in an SQLite database. I was using
>> layer.startEditing()
>> layer.addFeature(feature, False) OR layer.addFeature(feature, True)
>> layer.commitChanges()
>> After about 10 to 15 features the system began to slow significantly
>> with periods of 100% CPU usage increasing until the system became
>> unusable.
>> To assess if this was my code or something in QGIS 2.4 on Debian Wheezy,
>> I created a simple point shapefile and added points and saved each time
>> (both trying just saving and stopping editing and saving) and again at
>> about 10 to 15 points the system failed.
>> My request is simple.
>> 1. Can someone else confirm that this happens on other systems
>> 2. If so, is there some way around this until this fixed?
>> Thanks
>> TSW
>> Trevor Wiens
>> Apropos Information Systems
>> aproposinfosystems.com <http://aproposinfosystems.com>
>> Calgary, Alberta
>> Ph. 403-973-5901
>> Fax 780-666-4580
> __________ Information from ESET Mail Security, version of virus signature
> database 10283 (20140820) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140820/865f64ed/attachment-0001.html>
