[Qgis-developer] Processing Toolbox in QGIS 2.0.1-Dufour does not show some toolboxes
Victor Olaya
volayaf at gmail.com
Thu Feb 13 05:37:47 PST 2014
Looks like you have the simplified mode enabled, which does not show
providers (SAGA, GRASS, etc), but just one single group with all
algorithms. In the lower part of the toolbox there is a widget to
select the advanced interface. The simplified interface is the default
one in 2.0.1
If you have just compiled it, don't forget to update Processing using
the plugin manager. There is a newer version than the one shipped with
QGIS 2.0, tagged as experimental in the plugin repo.
Hope this helps
2014-02-13 14:28 GMT+01:00 Roberto Antolin <rantolin.geo at gmail.com>:
> Hello all,
> I am experimenting some issues with Processing Toolbox in QGIS 2.0.1-Dufour.
> Yesterday, I compiled qgis 2.0.1 using the zip version on github [1] without
> problems. However, the Processing Toolbox only displays three toolboxes:
> GeoAlgorithms, Models and Scripts. The rest of them are all "active" within
> the "Processing options" menu but are not shown. This happens even though I
> move "processing" folder from $HOME/apps/share/qgis/python/plugins/ (defined
> by --prefix) into $HOME/.qgis2/python/plugins.
> I deleted my compiled version and installed qgis from the repositories
> following the instructions given in [2] (ubuntu, precise). QGIS works fine
> and the toolbox behaves in the same way, though.
> Does somebody know what is happening here?
> [1] https://github.com/qgis/QGIS/archive/master.zip
> [2] http://www.qgis.org/es/site/forusers/alldownloads.html#ubuntu
> Regards,
> Roberto.
> Qgis-developer mailing list
