[Qgis-developer] QGIS MetaSearch Catalogue Client 0.1.0 released
Tom Kralidis tomkralidis at gmail.com
Wed Feb 19 04:00:15 PST 2014
Hi Stefan: thanks for the info.  This is the dreaded metadata "link types" issue.
If possible, can you open an issue on this so we can discuss this in the ticket?
Thanks
..Tom
On Wed, 19 Feb 2014, Blumentrath, Stefan wrote:
> Date: Wed, 19 Feb 2014 11:54:04 +0000
> From: "Blumentrath, Stefan" <Stefan.Blumentrath at nina.no>
> To: Tom Kralidis <tomkralidis at gmail.com>
> Cc: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
> Subject: RE: [Qgis-developer] QGIS MetaSearch Catalogue Client 0.1.0 released
> Done.
> BTW, the problem that I could not add WMS / WFS is likely to be on the CSW side and not the client side, cause it worked for some WMS...
> I was using the CSW for "official" map data in Norway provided by geonorge:
> http://www.geonorge.no/geonetwork/srv/no/csw?
> There are several / many WMS listed which cannot be added... Would you mind double checking if this is a server-side problem?
> Cheers
> Stefan
> -----Original Message-----
> From: Tom Kralidis [mailto:tom.kralidis at gmail.com] On Behalf Of Tom Kralidis
> Sent: 19. februar 2014 12:32
> To: Blumentrath, Stefan
> Cc: qgis-developer at lists.osgeo.org
> Hi Stefan: thanks for the info/kind words.  Yes, can you file a ticket at https://github.com/geopython/MetaSearch/issues/new with the steps taken, so we can reproduce and fix the issue.
> Thanks
> ..Tom
>> Date: Wed, 19 Feb 2014 08:06:59 +0000
>> To: Tom Kralidis <tomkralidis at gmail.com>,
>> released
>> Hi Tom,
>> Thank you (and your team) very much for this excellent plugin! Very valuable!
>> I tested version 0.1.1 (in QGIS 2.0.1 on Win7) and love it already.
>> Adding WMS/WCS/WFS however does not seem to be active yet, and using the "back" arrows throws an error:
>> Traceback (most recent call last):
>>  File "C:\Users\ninsbl/.qgis2/python/plugins\MetaSearch\dialogs\maindialog.py", line 572, in navigate
>>    if res == QMessageBox.Ok:
>> UnboundLocalError: local variable 'res' referenced before assignment
>> Should I file a ticket?
>> Still the plugin is already very useful and personally I think it should make it to QGIS core in the long run!
>> So, thanks again,
>> Stefan
>> From: qgis-developer-bounces at lists.osgeo.org
>> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Tom
>> Kralidis
>> Sent: 18. februar 2014 21:16
>> To: qgis-developer at lists.osgeo.org
>> Subject: [Qgis-developer] QGIS MetaSearch Catalogue Client 0.1.0
>> released
>> The MetaSearch team announces the release of MetaSearch 0.1.0.
>> The 0.1.0 release marks the initial offering of a CSW client for QGIS 2, with significant features to enable plug and play interoperability with OGC CSW services.
>> - find and bind functionality allowing users to discover and add
>> layers from WMS, WFS, WCS, or WMTS services dynamically to the map
>> - template-based service and record metadata view, allowing for custom
>> templating of responses
>> - visual footprint of CSW results
>> - display of all metadata access links, allowing users to
>> click/download data to add to QGIS
>> - spatial and aspatial querying of CSW services
>> Version 0.1.0 represents a significant engineering effort to bring CSW support for QGIS 2, make the codebase sustainable/extensible and easy for developers and documentation teams to make contributions.  Longer term plans include:
>> - supporting other catalog APIs (CKAN, etc.)
>> - making MetaSearch part of QGIS core
>> - transifex localization
>> - display thumbnail/browse images
>> We are looking for feedback and testers for the plugin.  Comments, bugs, features/enhancements are welcome (IRC, GitHub issue tracker, etc.).
>> The full list of enhancements and bug fixes is available at
>> https://github.com/geopython/MetaSearch/issues?milestone=1&page=1&stat
>> e=closed
>> The plugin is available from the QGIS Plugins Repository at
>> http://plugins.qgis.org/plugins/MetaSearch
>> Testers and developers are welcome.
>> The MetaSearch team.
>> http://geopython.github.io/MetaSearch
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
