[Qgis-developer] Date/time widget
Tim Sutton
lists at linfiniti.com
Wed Jan 8 05:53:10 PST 2014
Ok it works for me now - apologies for the noise!
T
Sent from my mobile
On 08 Jan 2014 3:45 PM, "Matthias Kuhn" <matthias.kuhn at gmx.ch> wrote:
> Hi
> Paolo:
> I haven't checked for #8818, #8820 yet, but didn't pay attention to solve
> them either... Let's see once it's finished. If there is still a problem,
> fixing should be easy and straightforward.
> I will send you information in a PM soon.
> On 01/08/2014 02:36 PM, Tim Sutton wrote:
>> Hi
>> By the way - unless something has changed, the 'drag and drop' form
>> designer is badly named - it doesn't allow either dragging or dropping.
>> Perhaps it should be renamed to 'Interactive form designer' or something?
> We can rename it if the name "Interactive form designer" is clearer, I
> don't care (whereas the name "dual view" was admittedly a bad choice...)
> but you should be able to drag any field from the table on the left into
> the tree. Does that not work?
> Matthias
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140108/c6bbb0e5/attachment-0001.html>
