[Qgis-developer] [QGIS-UX] option to disable font vectorization in labels
Larry Shaffer
larrys at dakotacarto.com
Tue Jan 21 13:01:39 PST 2014
Hi Anita,
On Tue, Jan 21, 2014 at 10:56 AM, Anita Graser <anitagraser at gmx.at> wrote:
> Am 21.01.2014, 10:24 Uhr, schrieb Vincent Mora <vincent.mora at oslandia.com
>> The question is where to put this option ?
>> So far I think of 3 places:
>> - a global project option: you will see the result in the canvas as you
>> work
>> - a layer label option: in this case you have to change the behavior for
>> each layer
>> - a composer option: you make the choice when you export to svg, in this
>> case you don't see the result until you open the svg
> Thanks for addressing this issue!
The issue is not actually fixed. The associated pull request only turns on
3/4-working code. A full fix should be forthcoming after the feature
freeze. If a full fix for exporting text-as-text for SVG/PDF can not be
verified with unit tests, then the option will need to be removed.
Regards,
Larry
> For me, the most obvious place to put this option would be in the print
> composer. Maybe close to the "print as raster" option?
> Best wishes,
> Anita
> anitagraser.com
> QGIS-UX mailing list
> QGIS-UX at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-ux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140121/a3fa188f/attachment.html>
