[Qgis-developer] Cad-Input for QGIS prototype
Andreas Neumann
a.neumann at carto.net
Mon Jan 27 07:35:04 PST 2014
It looks very useful.
I also think this should be in the core of QGIS - or before that it
would be nice if it could be integrated in Bernhards Ströbl
DigitizingTools plugin.
I hate it when I have to enable 5 different plugins to get a decent
digitizing environment. And when I teach QGIS to new users it is most
confusing if functionality is spread among too many plugins.
So if possible - please integrate such functionality in existing plugins
or into QGIS core rather than starting a new plugin.
Thanks a lot for your efforts.
Andreas
Am 27.01.2014 10:52, schrieb Bernhard Ströbl:
> Hi Antonio and Olivier,
> I will comment below.
> Olivier, thanks for the move.
> Am 26.01.2014 06:05, schrieb Antonio Locandro:
>> Hi Oliver, thanks for copying me in this email
>> Let me tell you that I have installed your prototype and tested it. I do
>> think something like this is needed and I do like the fact that it works
>> with other tools directly. I like the fact it gives you guidelines of
>> what it will do like in CAD software. I think it would be nice to add
>> also the possibility to use right clicks for actions
> I have not tried your plugin but watched the video. Looking at defining
> an angle it should be definable relative to a) the last segment b) North
> c) another (helper) point
>> To address your points
>> 1) yes this feature is needed in QGIS, other COTS software have this
>> functionality as Advanced Editing and I do rely heavily daily on this
>> type of things for my job and is amongst several reasons why we cant
>> switch for QGIS. I know the main user base of QGIS probably use it only
>> for analysis but for some of us we need to digitize precisely
>> coordinates based on field data or to create specific features.
> would be useful here, too
> Although I think most CAD functions for which currently nothing similar
> is available in QGIS are for construction I still think, it would be
> great to have them. (Of course not those to create 3D screws :)
>> I would vote to keep to make it part of core as Advanced Tools or
>> something, I also think it would be quite nice to merge the different
>> CAD-like tools into one and have all this contributors who made this
>> individual plugins work as a team. Resources are not always available
>> and to join forces to me seems a better approach
> The digitizingTools plugin is trying a similar approach, namely to
> combine efforts and present _one_ plugin.
>> 2) I would leave that for developers
>> 3) I cant code, at least I am not at that level. I am just learning
>> python and it might take some time to achieve a level to make something
>> useful. I can however test the plugin and suggest features. I think the
>> best way is to add issues in the github repository of bugs, improvements
>> etc.
> I am working more or less continuely on digitzingTools (if need arises).
> I can support in Python coding.
>> 4) Some ideas to start with, I will add them to github so you have them
>> there also. I understand it is a prototype to see if it gathers traction
>> but I feel it will
>> - snap to midpoint (snapping options to behave like in CAD software)
> more easy control over snapping in general: currently snapping has to be
> set for each individual layer seperately: switch snapping on/off
> completely, set snapping behaviour for all layers at once (segment,
> node), additional snapping options needed: snap to middle of line, snap
> perpendicularly
>> - Add trim line
> +1
> trim two lines so they form a corner
>> - Add extend line
> digitizingTools already offers continuing digitizing of a line (though
> not CAD like in prolonging the line in the direction of its last segment)
> would be great to extend several lines until they meet
>> - Add ability to create arcs e.g. Tan Tan Radius; select center and add
>> radius
> question would be how this is to be stored in GIS format
> - general: provide a means to move the map while any digitizing tool is
> active. possible solutions
> a) shift/ctrl + drag
> b) add scrollbars (looks arkward but users at once know what to do)
> my 2cts
> regards
> Bernhard
>> - Add the ability to draw by deflection angle apart from perpendicular
>> and parallel
>> - Maybe add the possibility to add x,y in DMS, DM, DD when working in
>> WGS84
>> - The plugin already adds the function to calculate within fields. I
>> think one useful thing in length is that by default it is m (or the epsg
>> default unit I guess ft might be for some) and that you can add
>> different units by adding the appropriate abbreviation like in other
>> COTS e.g.
>> 18 ft
>> 1 NM
>> 1 SM
>> From: olivier.dalang at gmail.com
>> Date: Sun, 26 Jan 2014 03:08:27 +0100
>> Subject: Cad-Input for QGIS prototype
>> To: qgis-developer at lists.osgeo.org
>> CC: diego.gnesi at gmail.com; Stefan.Ziegler at bd.so.ch;
>> bernhard.stroebl at jena.de; antoniolocandro at hotmail.com
>> Dear list,
>> Some times ago, on this list, we discussed[1] about real CAD-like input
>> for QGIS, and since I do myself long for such a feature very much, I'd
>> like to reopen that discussion by *proposing a python prototype*.
>> I know there are already a few plugins aiming in that direction
>> (CadTools, ImprovedPolygonCapturing, NumericalInput and a few other).
>> They provide the functionality, but not the ease of use you can find in
>> CAD packages.
>> One key aspect is that they are all specific tools, and do not work with
>> The prototype is inspired from Archicad's input method which allows to
>> combine numeric input with mouse input in a very efficient and flexible
>> manner, to get the best of both.
>> It is currently very raw and not well tested at all... It also relies on
>> a lot of dirty hacks, since the python API is not well suited for this
>> type of plugins (have a look at the README on the github page for more
>> details).
>> *DEMO (video) : https://vimeo.com/85052231*
>> *GITHUB (readme, download...) :
>> https://github.com/olivierdalang/CadInput*
>> Please, tell me what you think :
>> 1) Concept
>> - Does this kind of input seem interesting to you ?
>> - How does it fit in a GIS-environment ? Since it comes from a CAD
>> environment, maybe it's more suited to designing than digitizing.
>> 2) API/Core modifications (read
>> https://github.com/olivierdalang/CadInput#technical-notes )
>> - How do you see the suggested improvements ? Are they feasible ?
>> - Does developing this as a python plugin make sense, or does it have to
>> be in the core from the start ? (I'm not familiar with core developing)
>> 3) Collaboration...
>> - Is anyone of you currently working on the same topic ?
>> - Would anyone have some time/interest in collaborating on this feature ?
>> 4) Other ideas are welcome !
>> Thanks for your attention,
>> Olivier
>> [1]:
>> http://osgeo-org.1560.x6.nabble.com/Make-QGIS-interact-with-LibreCAD-td5048565.html
>> (To those from this discussion I cc'ed, I though you may be interested,
>> I hope you don't mind)
>> __________ Information from ESET Mail Security, version of virus
>> signature database 9338 (20140125) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> signature database 9340 (20140126) __________
> http://www.eset.com
> Qgis-developer mailing list
